Won't run past half throttle!!!!!
Craig
08-09-1999 06:54:27
I rebuilt the carb on my TO-20 and did a complete tune-up. Found out that the timing was off and adjusted that. My problem now is that the tractor sputters when trying to power up past half throttle. I adjusted the carb according to the shop manual and it just doesn't seem to work! It starts right up and idles fine but thats about it. I am getting good fuel flow but it acts like it is still starving for gas. Any suggestions?
kevin
08-10-1999 05:57:46
 Re: Won't run past half throttle!!!!! in reply to Craig, 08-09-1999 06:54:27
Two things to check. First, try turning the main fuel needle (large knurled screw) on the carburetor out in 1/8 turn increments. In leans the fuel, out richens the fuel. I had to adjust mine out more than the original setting to have the tractor run well under load. Second, it sounds as if your timing isn't advancing. The setting for the TO-20 is 7 degrees BTDC at 400 rpm, with 31 degrees full advance. The distributor points gap is 0.022 with the DELCO-REMY distributor. If you have the replacement PRESTOLITE distributor, the settings are different. The centrifugal advance weights in your distributor may be rusty and not letting the distributor advance properly. Check with a timing light to see if you are getting the proper advance.
GEORGE
08-10-1999 19:19:59
 Re: Re: Won't run past half throttle!!!!! in reply to kevin, 08-10-1999 05:57:46
If it is misfiring, maybe point gap too wide.
