Temp gauge
Frank Biscardi
12-16-2000 04:14:31
I can't seem to find a temp gauge that fits the drilled out hole in the water pump housing of my TO-20. Some older farmers tell me that the Z-120 can get cracks in the block when overheated and that a temp gauge is important. Any thoughts about this?
Thanks
Frank
Tom B
12-16-2000 06:18:53
 Re: temp gauge in reply to Frank Biscardi, 12-16-2000 04:14:31
Frank,
I just replaced the temp gauge on my TE20.
What I found was the fitting that came with the gauge wouldn't fit into the engine neck. What I ended up doing was using the old large fitting that screwed into the neck. But, I had to drill a larger hole in it because the sensor on the new gauge was about .030 bigger than the original one. The sensor and fitting on the guage then screwed into the original fitting.
Also, the lead to the gauge was too long. I wrapped the excess around a large screw driver to make a neat coil and tucked it out of sight under the battery stand.
Might not be the best method but it worked for me. Tom B
Topeka Ks.
