rear tractor tire losing air
Grass Roots Far
01-24-2007 17:10:49
I have a slow leak in one rear tractor tire, although it seems to be getting worse. Knowing how much new tires cost to buy and mount, are there any stopgap measures I can take? This is a 1952 TO-20 tractor, which I have had for 6 years. I have no idea the age of the tires, although they do not match one another.
phil(va)
01-25-2007 07:49:07
 Re: rear tractor tire losing air in reply to Grass Roots Farmer, 01-24-2007 17:10:49
If the tire and rim are pretty old there is an excellent chance you have a leak because of rust in the rim that has worked a hole into the tube. I would remove the wheel and take it to my local tire co-op to have them pull the tube and look at the rim, but if you can do that yourself that will save a lot of time and a little money. Chances are you may have to remove the rust out of the rim before you install a new tube or it will leak again.
mike a. tenn.
01-24-2007 18:14:14
GRF...you shouldn't need to replace the tire unless it's rotted, torn or split open to the point that the tube is coming thru it, all you need to do is patch or replace the inner tube. this can be done without removing the wheel from the tractor if you have or can borrow the right tools to break the bead and then pop one side of your tire over the rim. my neighbor and i have done it several times. otherwise you can usually get it done at your local co-op. as far as i know there is no other way to permanently fix your tire leak.
-mike
