T O 35 pos. or neg. ground?
D Roberts
12-14-2000 17:30:44
Have a to 35 with 12 volt gen.I noticed it was hooked up -groud at battery. I just bought this tractor 3 wks ago.I was talking to a tractor friend of mine who told me it should be + ground.He told me the wire on distributor to coil would be + to points if it is + ground.Now mind you the charging system was working fine until he told me this.I changed the terminals at bat.to make it + ground.I started it up for less than a minute and the ammeter went over to 30 amp.Is it to late to polarize it or should I have waited til my points were fried? Any help is welcome. Thanks
Paul in NM
12-15-2000 14:43:14
 Re: T O 35 pos. or neg. ground? in reply to D Roberts, 12-14-2000 17:30:44
The 12v TO-35 has a (-) ground. Change the battery terminals to what they were originally. You will probably have to recharge your battery before trying to start it. Check the wiring diagram below.
Paul
Terry Hook
12-22-2000 16:13:06
 Re: Re: T O 35 pos. or neg. ground? in reply to Paul in NM, 12-15-2000 14:43:14
How about the 6V TO35? Is it positive or negative ground?
Tom Callihan
12-24-2000 13:49:57
 Re: Re: Re: T O 35 pos. or neg. ground? in reply to Terry Hook, 12-22-2000 16:13:06
I own a TO35 6 volt system and it is positive ground. Also the tractor is dark green chassis and flint gray sheet metal. FYI
