to30 lift
TONYe1
01-17-2007 10:57:12
my lift was leaking after the oilgot hot and would not lift again until it the oilhad cool down i replaced the cly it had very bad grovesinit also replaced piston and rings all new now seems to work good now but with a 5ft. disk when you push in onn the clutch it will fall to the ground is that the way it works tony
phil(va)
01-18-2007 06:39:55
 Re: to30 lift in reply to TONYe1, 01-17-2007 10:57:12
As Jerry said it should not drop down right away when you depress the clutch. Could also be the check valve, which is the one that looks like a spark plug and is at the back and bottom. It costs about $25 and is available from the dealer and takes an 11/16 wrench.
tonye1
01-17-2007 16:32:39
thanks jerry i well work on it some more then
Jerry/MT
01-17-2007 14:08:45
The hydraulic pump is transmission driven and if the clutch is disconnected, the pump stops running and there is no hydraulic pressure or flow to the cylinder.
The control valve should hold the position if the lever in the full back position. It should leakdown in no less than 15 minutes.
Your contol valve may have dirt in it, not allowing it to close fully or you may have another leak. It could be the supply tube to the cylinder(?) which is located in the right hand corner of the pump chamber
steveormary
01-17-2007 20:01:52
 Re: to30 lift in reply to Jerry/MT, 01-17-2007 14:08:45
Some years back I worked on the TO-30 hyd. pump.
Cleaned it up and replaced some broken and worn parts with parts not quite so worn.The tractor would hold the back blade up for about 2 days to start with. Then it got to where the blade would drop in aout ten min.
sreveormary
