TO-20 Exhaust Mount
BrianJ
01-15-2007 11:28:36
I have a new exhaust pipe and muffler for my TO-20 and need help mounting it. The new exhaust assembly (horizontal) is about 12 inches longer then the one currently on the tractor. The one on the tractor now has a clamp, around the tailpipe, mounted to the underside of the foot board. How do I mount the new exhaust assembly (the clamp fits around the tailpipe, not the muffler)? Is there somewhere back by the axle housing that it should be mounted to? Does anyone have a picture showing the underneath of a TO-20 that shows how to mount the exhaust? Thanks in advance!
RCollin
01-20-2007 18:44:28
 Re: TO-20 Exhaust Mount in reply to BrianJ, 01-15-2007 11:28:36
There should also be a support on the front side of the differential down to the muffler. The bracket attaches to the stud, directly behind the brake rod. You could make one using 3/4"x8-10 gauge flat. It wraps around the muffler and tightens up with a machine screw, and has a 7/16" hole to slip over the stud.
ric1
01-15-2007 15:41:17
i would double check to see if maybe they gave you the wrong exhaust system. or get some of that adjust strap with the holes in it and make your own where its suppose to be . or can you cut off the excess length of exhaust pipe. just some thoughts
