drawbar for TO-20
Grass Roots Far
01-14-2007 11:07:17
In trying to figure out my TO-20(1951) drawbar setup, I find a clevis assembly bolted to the underside of the transmission. This slot is 1/4" so aftermarket drawbars will not fit in this slot. Can anyone tell me what I should be looking for. There is no other bar support/connection currently on the tractor-by that I mean nothing around the PTO. Thanks in advance for any advice. I have searched the archives and found nothing.
Grass Roots Farmer
01-28-2007 16:21:30
 Re: drawbar for TO-20 in reply to Grass Roots Farmer, 01-14-2007 11:07:17
After poking around the Web, I think I found the drawbar assembly my tractor was set up for. The Clevis pin assembly was welded underneath the transmission and the slot was just the right size for a "1950 Ford Original swinging drawbar", which is simply a bar slid in the clevis assembly and connected to the horizontal drawbar assembly. I don"t have a photo but found one in the Ford archives. I fashioned one close enough and this works to help stabilize the manure spreader. Thanks for all of your ideas along the way.
johnpop1
01-15-2007 04:32:07
Having grown up around Fergusons, I think I can safely say that what you have on your tractor is the mount for a Ferguson swinging drawbar. The actual drawbar fastened to the bracket you describe with a short large diameter pin maybe 1" in diameter and 2 1/2 inches long. The support for the swinging drawbar slid into grooves on both sides of the bracket on the underside and then had an arm that went up to a long pin that slid through a bracket just below where the top link would go. This was a very cleavor and elegant drawbar assembly that could be rapidly removed when a 3-point implement was to be attached by removing only 2 pins which could stay with the tractor. We still have them on both Fergusons on the family farm. Neither is often used but both have been on the farm since new and both have rarely seen any time outside when they weren't actually being used.
Jim in OH
01-15-2007 04:54:12
 Re: drawbar for TO-20 1000 words in reply to johnpop1, 01-15-2007 04:32:07
third party image
Is this it?
Irv (Ia)
01-15-2007 13:08:29
 Re: drawbar for TO-20 1000 words in reply to Jim in OH, 01-15-2007 04:54:12
Jim Is that an actual Ferguson drawbar? The one on mine is like the one pictured below, but I like the looks of this one. I thought I might make one sometime.
Jim in OH
01-16-2007 05:47:09
 Re: drawbar for TO-20 1000 words in reply to Irv (Ia), 01-15-2007 13:08:29
Maybe you have seen the posts in the archive... As I understand it, the one I showed in schematic is an original ferguson 30 drawbar. Here is another picture from the gallery.
third party image
There were many other aftermarket versions; even Sears had one (below). third party image
And of course, the most popular aftermarket one now is like that in the picture you mention (below). third party image
third party image
As far as I know, that is all that is available today. I think that it is a copy of what was offered for the ferguson 35, only the copy is a bit lighter weight construction than the original. It can be fit to the early fords also.
Jim
WBinPA
01-14-2007 15:24:46
You may have the mount for a Sauder brand front snowplow. It is similiar to a drawbar mount. I found this setup on my TO 30.
steveormary
01-14-2007 13:03:41
You need to get an owner/operator manual. You might be able to get a cross drawbar and drawbar stays at TSC. This would be a different set up then you are looking at. It is all we ever used for a drawbar on our Fergusons and Fords.
Also,FENA(Ferguson Enthusiasts of North America) puts out a news letter 5 times a year.
You may want to subscribe to that.
steveormary
Grass Roots Farmer
01-14-2007 15:39:16
 Re: drawbar for TO-20 in reply to steveormary , 01-14-2007 13:03:41
I used the cross drawbar with additional stays and these bent when I used the assembly to pull a manure spreader. As the manure moved to the back of the wagon, the stabilizers simply bent from the extra weight imbalance. I would like to use this slot and clevis pin assembly to use the tractor body and not the lift arms to hold the load.
ric1
01-14-2007 15:25:26
a few years ago i purchased a drawbar thatslides into a under rearend mount. its really nice for pulling things with a tongue such as wagons /trailors /manure spreaders or whatever it might be .it is alot more stable than the typical drawbwar that fits to your lift arms .i paid around $95.00 dollars for it.i couldnt imagine doing without it.
Crem
01-15-2007 08:00:33
 Re: drawbar for TO-20 in reply to ric1, 01-14-2007 15:25:26
third party image
Here is the aftermarket drawbar on my TO-20 Ferguson. It works well, but cannot be in the fully extended position when using the rotary mower. I found that out the hard way as when it tilted just right, the blade nicked the end of the drawbar and sent a chip of hot steel flying. The chip burnt right into the skin in my ear. I couldn't figure out what happened at first. Notice the thread repair on the adjustable arm that my brother did probably back in the eighties. The farmers did what they had to to keep things going.
