Fergie gets rigged for winter
George in MI
01-11-2007 17:25:23
third party image
I have two tractors and an old Dodge Power Wagon (flatfender type) used to manage the 150 inches of snow we get here in northern Michigan. One tractor has a snowblower mounted which works well for "big snow". The Powerwagon does well also but the banks eventually close you in. However, I didn't have anything for the snow flurries...anything up to 4 inches....especially when the ground was soft.
So I bought some chains for the TO-20 which normally hibernates through the winter and they have worked out great. I push backwards with a small blade so it doesn't dig up the soft (unfrozen) dirt. Since I have hills, not shown in the pictures, the tractor can now be used. By the way, it starts well...so far the coldest day I tried it was about 20 degrees, but it fired up quickly.
So here is one recommendation for chains...they really work!
Jeff in WI
01-24-2007 19:52:03
 Re: Fergie gets rigged for winter in reply to George in MI, 01-11-2007 17:25:23
I have a TO 30 with a blade on the front. I never use chains and the wheels have fluid and it is a great snow plow tractor, I overhuled it last summer, it runs like a top.
bllib in canada
01-20-2007 04:14:23
George by installing the bumper assembly to the axle, I'm assuming the axle/s no longer float independent of each other..... .....
Cheers
Dale in WV
01-17-2007 09:49:10
 Waiting for the first snow in reply to George in MI, 01-11-2007 17:25:23
Still waiting for our first snow here, near Martinsburg, in eastern WV. Got chains on the TO-30; fueled up the snowblower, too. Tried doing a snow dance, but apparently I don't have the right moves...
Tuck
01-14-2007 20:03:40
Chain searchers might try to find a set of two rail dual wheel truck tires. (designed to fit over both duals at once without any circumferential chain between the tires) Might be able to acquire inexpensively at an auction.
Mine work just fine on standard size tires.
gshadel
01-12-2007 08:00:24
that is one fine looking TO! And those are some fine looking chains... I know you spent a few $$$ on those chains. My driveway runs up a hill (not real steep). I usually can only push snow when going down hill, and can't do much going up hill, really slows down the snow plowing, but I'm usually out joyriding in the snow anyway... so it's hasn't been a big enough problem to spend the big $$$ on chains.... yet.
Is that a regular N bumper, or one of those bumpers that pivots so you can open the hood all the way? Nice looking bumper. I need a set-up like that... including the tow strap. My wife seems to enjoy getting the pick-up truck & horse trailer stuck in mud, snow, ditches, the neighbors yard, etc.
George
George in MI
01-12-2007 19:59:14
 chain info..Michigan location, front bar..etc in reply to gshadel, 01-12-2007 08:00:24
The chains cost about $250 including shipping, I also got the spring tighteners (not installed yet) for an additional $45.
I live on the Leelanau Peninsula near Traverse City. We got two feet in a couple of days in early December, then nothing until the last few days when we got the dusting you see in the picture. Where in MI are you?
The bar on the front is the kind that swings out to open the hood.
Also note, the tires are 14.9-24 which are oversize, and the fenders are from a TO35 I think because they have the little tool box area in the fenders.
As for the "nice" condition...the farther away you are the better it looks. It was red when I got it...apparently because MF dealers repainted them when they took them in on trade. I am in the process of painting it back to gray. But it is not a show-piece job. The engine is worn and smokes when cold, but quits smoking pretty fast. It runs well after that. I have a Zane Thang which is very helpful...I know you can make your own but this works well and can be installed in 10 minutes.
gshadel
01-14-2007 04:44:28
 Re: chain info..Michigan location, front bar..etc in reply to George in MI, 01-12-2007 19:59:14
George,
Oh, I'm not in Michigan, I'm one state below you in Ohio. I usually get enough snow to plow 2-3 times/year, but have had all rain this Winter so far.
I have a "Thang" too, I know exactly what you mean.
George
randy
01-12-2007 07:47:03
where in Michigan did you find snow???? That must be an old picture I too live in northern Michigan and my tractor has only been out of the shed 1 time back in mid nov. to push any amount of snow
mike a. tenn.
01-12-2007 04:22:56
yes...nice tractor! i solved the snow removal dilema in a different way...i moved 500 miles south from NE ill. to SW tenn. where even the THREAT of snow closes the schools and half of the businesses. you TO-20 guys are making me want to get mine back in the shop and get it going again. thanks for the incentive push.
Craig(DE)
01-12-2007 02:52:25
I would like to add chains to my TO_20 but I am worried about tearing up my blacktop. Although the way this winter is going, I won't be scraping any snow anyway. I have calcium in one rim that will get emptied out soon because it is leaking and the rim is rusted pretty bad. I replaced the other rim a couple of years ago because of the same thing.
Jerry/MT
01-11-2007 18:09:07
Nice tractor! I like you definition of snow flurries-4 inches of snow!
Just a comment though. You need to have some chain tighteners on those chains. They look very loose. You can buy chain tighteners or you can use rubber tarp straps to tighten them, about three per wheel. Place them across the diameter in three approximately equally spaced positions. It makes the chains more effective and reduces the wear on them.
George in MI
01-12-2007 06:32:21
 loose chains in reply to Jerry/MT, 01-11-2007 18:09:07
Yes, they are loose. I just put them on and I did buy the chain tensioners also...just didn't install them yet.
I don't go very far with it and it is all on dirt/gravel. I think I will really need to jack up the wheel to get them tighter.
Aaron Ford
01-12-2007 12:00:20
 Re: loose chains in reply to George in MI, 01-12-2007 06:32:21
Install tighteners, drive, tighten, drive, tighten, drive, tighten. This should work out any kinks, that develop. HTH
Let's go Mountaineers,
Aaron
