F-40 ...it appears to have been the coil.
jim cancil
12-31-2006 11:34:03
I'm the one who's tractor would die a slow death in about an hour's running...
After doing everything except change the air in all four tires. With your guidance, I went to PepBoys and got a new coil. I gather in 1957 this F-40 came with a 6v system but sometime it was switched out to 12v. Without looking at the coil on the tractor, I bought an internal resistor coil...when, of course, I needed an external resistor coil. ...back to town.
I changed the coil and BINGO: it runs great. It seemed (wishful thinking?) to start quicker and idle smoother. I ran it for about an hour doing light duty and it didn't falter.
So far, I got a new E German carb, points/condensor/cap...timed it by eyeball...and this $30 coil. I can't believe in 2006 I can leave something sit out for a decade, no more than 1/2 a tank gas ever and have it willingly come back for more work whenever I hit the starter. I can afford something newer...but how can you give up on an old horse who's willing to pull whenever you ask?!
Thanks all for all your help. I didn't change the coil before you coached me to - even tho' I thought about it - because my M-F dealer (30+yrs...) didn't think it could have been it. Thanks again.
j i m
Paul in AZ
01-01-2007 08:05:29
 Re: F-40 ...it appears to have been the coil. in reply to jim cancil, 12-31-2006 11:34:03
Your experience with the coil points out that for these tractors to run and run well, everthing component has to be working correctly. I have had similiar experiences with my Fregusons.
By the way, all F-40s came from the factory with 12v systems.
phil(va)
01-01-2007 06:48:07
I have found that the M-F dealers are not very helpful at this point for these old tractors. Sometimes I go to my M-F dealer for a part, but I try not to, and I only go to them when I know exactly what I want.
patsublett
12-31-2006 15:31:07
I have an F40 with a backhoe and front end loader on it. I use it at least weekly. Im sure there has been better tractors made but I don't know what they are. I am sure that they aren't painted green. Mine has been converted to 12v also and I have had 2 coils go bad in 35 years. Another strange thing happened about 5 years ago, got a miss, changed plugs, ran about 6hrs, started missing again, changed plugs, process repeated. I got tired of changing plugs every 6 hrs. Called Champion Plug. Rep said use a higher heat range plug. I think book calls for H12. I replaced with H16. That set has run fine for 5 yrs. I am gonna change them some day if I get around to it.
