Sparking problem with MF FE 35
Gareth
12-10-2000 05:17:37
there is no spark coming out of the spark plugs whenever we start the tractor why is this so????
the distibutor and coil are in working condition as we took them of our other working MF35 need help!!!!!
gareth
12-11-2000 13:04:07
 Re: sparking problem with MF FE 35 in reply to Gareth, 12-10-2000 05:17:37
thank you but i won't be needing to do anything, someone is coming out tomorrow to fix it!!
thanks again!!
taffy
12-11-2000 12:55:30
has the carbon & spring or the rotor arm dropped out of the distributor cap?
check wire from coil - is there a spark at the contact points? are plugs and leads good?
