TO30 leak down time
Dave
12-09-2000 07:09:07
what length of time should the 3 pt. hyds. hold up a heavy 5' box scraper. After the engine is shut off it only takes about 30 seconds for the hyds. to leak down completely. I changed out the gear oil and put in a combination of 80-90 gear oil, and 10-40 engine oil (about 50-50) which really woke up the hyds. on a cold morning. Before the fluid change I tried putting the lift arms under the horse trailer and lifting, in hopes there might be a piece of grass caught in the pressure safty valve and this would clear it. Not so. What is the normal leak down rate?
Dave
Morgan
12-11-2000 09:37:30
 Re: TO30 leak down time in reply to Dave, 12-09-2000 07:09:07
It should take about 10 minutes to fade down to the ground, sounds to me like you might have to service your hydrolic pump.
