What year?
David Beckett
12-26-2006 10:35:58
Through the useful information on this site, I have been able to identify that I own TE20. It has not been running for a number of years and plan to get it going this spring. The ID tag is missing on the dash under the steering wheel... so have no serial number to go by. The nubers on the side of the block are as follows Z120A-600 and below that number is A21X. On the rear axle housing are these letters LEVS T4E. Can some one tell me what year it is?
Many Thanks Dave Beckett New Brunswick Canada
John (UK)
12-26-2006 16:25:02
 Re: What year? in reply to David Beckett, 12-26-2006 10:35:58
From the engine number it must be a very early one, either 1947 or 48, more likely 47 tho. The LEVS on the casting should be LEYS, they are the people who used to make them. You can get some idea of the date it was made if you look forward of the left side round inspection cover below the seat, it will have something like 23 4 48 which is 23 April 1948 BUT that is only the date the casting was made, that casting would be used in production within about 3 or 4 weeks of that date. That is about as near as you will get, the engines were not used in numerical order so you can't check it that way but as it is a very low number it must be one of the very early production tractors.
