clutch hub question
mike mcmurray
12-26-2006 05:58:46
Happy belated Christmas to everyone out there! Since I am rebuilding my 1951 TO 20, I figured it would be a good time to do the clutch as well, since the engine is removed. However, I am unsure of which clutch plate to order (friction disk). This site only shows a disk for a 1 3/8" hub shaft for a TO 20. One of my catalogues shows only the 1 1/8" hub for the TO 20.(it also only shows the TO 30 as having the 1 3/8 hub)....that same catalogue shows only a replacement kit for a 1 3/8 hub. I couldn't find any listings of the 1 1/8 or 1 3/8 anywhere in the clutch portion of my service manual..... I am completely lost and want my facts straight before I go ahead and order....Have a good day, mike mcmurray
mike mcmurray
12-27-2006 04:34:57
 Re: clutch hub question in reply to mike mcmurray, 12-26-2006 05:58:46
Thanks gentleman! Have a good day- Mike Mc.
John (UK)
12-26-2006 16:18:28
All the TO20/30 and TE20 series ALL have 1-3/8" centre spline, non have 1-1/8". It is as the other guys tell you....John
PS the only 1-1/8" splines are on the PTO shaft at the rear.
Jerry/MT
12-26-2006 21:09:02
 Re: clutch hub question in reply to John (UK), 12-26-2006 16:18:28
John I thought his guy was confusing the engine clutch with an ORC until I looked in the Sparex catalog and there is a clutch listed with 1-1/8" inch spline hub for a TO-35. Could that be the the second clutch for the dual clutch in the deluxe model of that tractor with live pto?
John (UK)
12-27-2006 04:48:29
 Re: clutch hub question in reply to Jerry/MT, 12-26-2006 21:09:02
Yes Jerry you are correct in that. Have you noticed in that Sparex parts list they have the wrong sizes listed in the columns, they have the 1-1/8" listed as the Main drive plate and the
1-3/4" listed as the PTO plate. Not only us that can make mistakes.
gshadel
12-26-2006 14:59:25
Mike, the clutch disk on this site, with the 1 3/8 hub is the right one. I installed one myself. I don't know what the 1 1/8 hub is referring to in your catalog.
George
Jerry/MT
12-26-2006 13:17:30
Sparex lists a 1-13/8 x 9 in OD x 10 splines for the TO-20, -30, -35. The TO-35 has another clutch listed but since you have a TO-20, that doesn't apply to yur case. The Sparex Number is S 60693 and the corresponding Ferguson part number are 180241M91(TO-20, -30). Hope this helps.
