The amount of volume needed for loader hydraulics.
Paul Kingsbury
12-18-2006 21:25:22
I just put a new Hyd pump onto my TO-30 Ferguson front loader. I wanted to increase the volume and PSI to also be able to operate a small backhoe. I got a Case D-100 that will dig about 7 1/2 feet; I converted it to a 3 point attachment. It weights about 1200 lbs. the size of many of the other 3 point aftermarket backhoes.
I put a Haldex Cast Iron Hydraulic Gear Pump 2.6 Cu. In on, and made a power beyond coupler and mounted it to the rear fender. This is really TOO much pump. A better choice would have been from 1.6 to 2 cubic inches.
So anyone looking at replacing their Hyd pump on a 30 hp tractor this should be a good starting point.
Gerald J.
12-19-2006 00:53:57
 Re: The amount of volume needed for loader hydraul in reply to Paul Kingsbury, 12-18-2006 21:25:22
When I replaced the too big PTO pump on my loader and back hoe (MF-236 loader, Long 1099 back hoe, MF-135 tractor) I went to a 5 gpm at 1800 RPM pump running off the front of the crankshaft. For those that was right. When I moved the loader and back hoe to my JD 4020, I put flow restrictor lines in the feeds to the two implements and adjust them for smooth operation, probably in the 3 or 4 gpm range. Deere adjusts the original (early 4020) remote valves for 5 gpm so it takes 5 seconds for a 3" cylinder to make a stroke. Faster than that completes the stroke before the operator can back off on the valve. And I like that speed or a little slower for the loader and back hoe. Not so fast that I have to operate the valves with sandpapered finger tips to not jerk the equipment around but can work with gloves and touch callouses.
But with the engine operated pump, you can slow it down to a fast idle and moderate the cylinder motion without looking digging pressure.
Gerald J.
