In need ofd some advice
JS13
12-18-2006 12:59:23
I recently bought a TO 20 Ferguson,my (winter project,) it is in need of lots of tlc, any way my concern at the present is this, I acquired a pair of lower lift arms that have 3/4 in sockets and I need to change the ball sockets to 7/8" how do I take out the old sockets ,go easy on me now,I,m still learning..
Leroy
12-22-2006 05:59:42
 Re: In need ofd some advice in reply to JS13, 12-18-2006 12:59:23
Are you sure you measured correctly? Cat 1 lift that you have on all Fergusons all have 7/8" balls, now a Cat 0 that is for garden tractors have the smaller pins and also would be shorter, if that is what you bought take them back and get the correct ones. If you try to weld a new ball on instead of a broken one the chances that it will work correct are very slim as if you get the length even 1/16" off it will cause the lift and whatever you have on it to pull sideways, the more off in length the more sideways it will pull. Also the top link uses 3/4" ball and pins so do not confuse them.
JS13
12-22-2006 11:06:18
 Re: In need ofd some advice in reply to Leroy, 12-22-2006 05:59:42
Really appreciate you guys steering me in the right direction,guess things are not always as they seem ,guess the old saying that you can learn something new every day still holds true,thanks again every one for all the great advise.
JS13
12-21-2006 13:45:40
Thanks so much for the inf to all of you ,didn,t realize about the proper length and the consequences involved by using to long or to short , so guess I should look for weld on ends, appreciate all.
John (UK)
12-20-2006 09:25:51
It isn't just a matter of sticking some old lower links on the tractor, they do need to be the correct length or it will either have the implements too near the tractor that they catch on the wheels or they are too long and it wont lift as much as it should do.
Paul in Ms
12-19-2006 03:51:07
You can buy new replacement weld-on sockets. So cut off the old weld on the new.
