how to remove fenders on TO-20
George in Mich
12-14-2006 14:15:18
I know this sounds like a dumb question, but I am having a problem removing the fenders from my TO-20. It does have oversize tires and fenders from a TO-35.
I would just take of the wheels/tires off but they are loaded and I worry that they will be just too heavy to deal with. Is this a legitmate thing to worry about?
If I leave them on, I can't reach behind them to get to the bolts that hold the fenders on. It looks like the nuts are on top where I can't reach them and the bolt heads are on the bottom. They don't want to move, and without getting a wrench on the inside, what do I do?
phil(va)
12-15-2006 07:15:56
 Re: how to remove fenders on TO-20 in reply to George in Mich, 12-14-2006 14:15:18
As the others said, probably you are going to have to remove your wheels. Here is a tip for doing so by yourself. As they said, keep them upright. That isn"t too hard if you are careful and create a place to lean them before you start. Also, keep pets and kids out of the way, just in case. When you put them back on, put two pieces of vinyl on the floor under them so you can slide them ever so slightly to help line them up with the lugs. That helps a great deal. I"m only 170 lbs, and I"ve replaced a number of loaded rear wheels that way. Also, and this is pretty obvious, do one side at a time to keep the tractor stable while you work on the fenders.
John (TR)
12-14-2006 21:49:13
I've pulled fenders on 4 or 5 tractors and to date only one set came off without a cutting torch. The tires are going to be 300# range. Not too bad but keep them upright and dont try to stop them if they fall over. Find an area to lean them against while off. They are doable just be careful.
I usually end up cutting the heads off with the cutting torch and driving them out with a sledge hammer. The nuts usually come off but the bolts may be seized in the axel.
Irv ( Ia)
12-14-2006 16:33:28
It's really going to be tough getting those off if they were like mine. I heated my bolts about red hot and after cooling a little, put some PB Blaster on them and let them set. That usually works on about anything and I couldn't get the nuts off. The bolt threads were messed up on the bottom and the bolts were REALLY stuck in the axle. I finally cut the heads and nuts off, lifted off the fenders off and literally had to beat the remaining pieces out with a sledgehammer. I ground the bolt top around the outside edge so it wouldn't mushroom out. And all this with the wheels OFF! I think your's are going to have to come off too. Good luck.
