Looking for a Z120 crankshaft
TE-20 fan
12-12-2006 15:00:34
The TE-20 I bought developed a bad knock so I took it apart. The crank was wore real bad. I took it in to my machinist and he magnafluxed it and found a large crack that goes half way thru. I'm looking for another crankshaft. The crank from any 20 series will work. TO-20, TE-20, TEA-20. They are all the same. Can you help? Thanks.
gshadel
12-13-2006 12:51:52
 Re: Looking for a Z120 crankshaft in reply to TE-20 fan, 12-12-2006 15:00:34
If you are not in a big hurry, keep an eye on Ebay for a few weeks for a Z120 crank. There are parts for Fergys listed on there pretty regular from folks that are parting them out. A Z129 crank (from a TO30) won't work, you need a crank from a Z120, which was on the TO-20 & TE20 only.
Good luck,
George
John (UK)
12-13-2006 11:46:14
A crank from a Continental (TO20/TE20)will not fit into a Standard Motors engine (TEA) You can buy a crank from Sparex as part S42843 they also supply the bearings. You can also buy the crank from this site too. Click on parts above.
Paul in AZ
12-12-2006 16:06:27
You may want to do some additional checking about interchangeability.
My MF parts books says the crank for the TE/TO-20 is part # 1 750 280 M1 while the part # for the TEA is 825 216 M1.
The TE/T0-20 engines were Continentals while the TEA's was a Standard engine. I'd hate to see you buy the wrong crank.
