pilot switch
ian goodwin
12-11-2006 21:59:31
Help! Can someone help me with the wiring for the pilot switch on my TEF-20. I bought it without a wiring loom, I can make my own but need to know where the pilot switch wires go to.
John (UK)
12-13-2006 11:59:32
 Re: pilot switch in reply to ian goodwin, 12-11-2006 21:59:31
The main feed for the pilot switch is taken from the feed battery lead on the solenoid then to one of the terminals on the Pilot Switch then from the other terminal to the small terminal in the centre of the two main terminals on the solenoid. All the pilot switch does is to switch the solenoid on then the solenoid switches the Starter on. The pilot switch needs to be set correctly for switching on, if it isn't set correctly it may damage the starter and ring gear. I have the Information you need to set-up this switch. fergusontractors(at)tiscali.co.uk
jeff-oh
12-12-2006 06:15:48
Part two.
Jeff-oh
12-12-2006 06:13:22
The Ferguson Enthusiasts site has the TEF-20 wiring diagrams. They are in two parts so examine each for you needs. I provided a link to the first you can maneuver to the other.
Jeff
