polarizing generator
John Mason, Mi
12-08-2006 05:35:09
I switched from 6V pos. ground to 12V neg. ground. The generator that was on the tractor was a 12V generator. I hear that I need to polarize the generator. How exactly is this done?
Thanks in advance.
souNdguy
12-11-2006 14:24:54
 Re: polarizing generator in reply to John Mason, Michigan, 12-08-2006 05:35:09
Before you go jumper ing or screwdrivering any connections.. decide what circuit type generator and regulator you have.
A circuit... jumper arm to battery hot.
b circuit... jumper field to battery hot.
Can't remember which you have? If you know the regulator is matched to the genny, then flip the reg over.. look for the wire wound bias resistors...
A circuit will have a bias resistor between ground and field.
B circuit will have a bias resistor between armature and field.. ( may have others present as well ).
Soundguy
John (UK)
12-08-2006 11:24:39
It is as Mark says.
mark from the fort
12-08-2006 10:13:43
I believe that just touching a wire between the A armature stud on genny, to the NON-grounded post on battery. I remember by thinking,"this tells the newly created charge to go from genny (arm.)into this post on battery to recharge battery."
Jerry/MT
12-08-2006 09:30:40
We used to do this with a screw driver across the field terminals on the generator, as I recall. But do a search i the archives because this question has been asked before.
