mf tractor
clarence thorne
12-07-2006 11:04:50
i have a 1954 mf farm tractor .trying to find out what model it is.it has several numbers on it.the numbers are:tea395210,on rear end400295.400207 and on engine0a12381,800508.
any help would be appreciated thanks
John (UK)
12-08-2006 11:00:35
 Re: mf tractor in reply to clarence thorne, 12-07-2006 11:04:50
You have told us what it is in those numbers you gave...TEA395210.(that is the serial number).it was made on the 17 or 18 June 1954 in Coventry UK. It is a Ferguson TEA model 12 volt, 85mm bore Standard Motors engine. 23.9 bhp The engine number is stamped in the block between the coil and the oil filler it will begin with S or SC and end in E
Jerry/MT
12-07-2006 11:18:24
These are not MF tractors they are Ferguson Tractors There should be a serial number plate on the dash board right above the steering column. If itsa TO-20 the serial will be TO 00001-TO 60000. A TO-30 will be TO-60001-TO 140000 (all used Continental Z series engines, Z120 for the TO-20 and the Z129 in the TO-30.). There is also a TEA-20 series which uses the Standard Engine (gas)and was manufactured in England and the TE-20 series manufactured in England using the Continental Z120 engine.
clarence thorne
12-07-2006 12:27:52
 Re: mf tractor in reply to Jerry/MT, 12-07-2006 11:18:24
the #on the dash above the sterring columne is tea395210 would this be the model #
Jerry/MT
12-07-2006 19:08:50
 Re: mf tractor in reply to clarence thorne, 12-07-2006 12:27:52
That's the serial number and if you go to the Research & Info section to the left of this page you can probably find out more info under Serial Numbers
phil(va)
12-07-2006 12:58:54
Yes, you have a Ferguson TEA tractor.
