Leaking seal(s) solution
DennisPinOhio
12-04-2006 07:39:28
I keep reading where some of you have problems with seals leaking. I just wanted to share some info about this "stuff" I found on Ebay. It is guaranteed to stop leaks. I"ve used it in my Ford truck to stop a bad power steering leak. It also worked in my TE 20 to stop oil dripping out of the "weep hole" at the bottom of the bell housing. It is good stuff and well worth a try before a tear down. NOTE: I have no connection with the company selling it. Search for Best Automotive Solutions on Ebay or Lesfred 4387.
Jim in OH
12-04-2006 12:30:48
 Re: Leaking seal(s) solution in reply to DennisPinOhio, 12-04-2006 07:39:28
... and if you have prevented the oil from leaking out, you will eventually ruin the clutch and perhaps the starter as it eventually fills the housing.. JIm
John (UK)
12-04-2006 12:12:14
If you stopped up the "weep hole" with that sealer it will fill up the Clutch Housing, it is there so that oil will leak it out if it gets in there.
DennisPinOhio
12-04-2006 13:59:16
 Re: Leaking seal(s) solution in reply to John (UK), 12-04-2006 12:12:14
My fault - I didn"t make myself clear. This chemical treats the SEALS. It actually causes them to swell and do the job they were meant to do.
Sorry about any confusion.
