oil leak
ed barnes
11-29-2006 18:22:32
i have a to 30. i am getting oil leaking out of the sparkplug ports...my father in law said that i could rig up a fitting to an air compressor and blow air in and then listen and see if i could hear the air escaping from either the blow by or the head to determin if it is the rings? does this work?
ben mc
12-06-2006 01:54:23
 Re: oil leak in reply to ed barnes, 11-29-2006 18:22:32
my TEA did the same on the way back from a show there was oil come out number 1 and 2 cylenders and it run realy badly took for ever to get home worst part is it was poring with rain but had a look next night and some one had tamperd with the carb was set way wrong wish i know that be for i drove it home
BobOHIO
11-29-2006 19:44:59
Hi Ed. I would do a compression check on the engine. You can pick up a gauge pretty cheap at most any auto parts store. A reading of 90 psi would be good but I have the feeling yours may be much lower.
