TO 35 Clutch
Greg in MS
11-28-2006 13:25:25
I have a couple of questions if anyone can answer them. I replaces the clutch friction plate a couple of months ago due to a leaking main drive shaft seal. The release bearing was also bad due to the leaking seal (I replaced the seal as well) so I replaced it as well as the bearing carrier. After getting the tractor back together, it seems that the bearing carrier return springs are hitting the clutch lever release bolts. The bolts have evidently turned some since one of the release levers has been moved, and my clutch gets hot and won't pull. I have adjusted the levers through the inspection plate under the clutch the best I can, but is there a good and easy way to do this through this small hole? Also, is there a way you can put the bearing carrier in upside down? The replacement parts looked the same as the ones I took out, but for some reason the bearing carrier springs hit and I don't see any way to fix that. Any advice would be appreciated.
John (UK)
11-29-2006 12:26:34
 Re: TO 35 Clutch in reply to Greg in MS, 11-28-2006 13:25:25
Haven't I answered this before? seems very familiar. The clutch isn't set up correctly, the levers are too low and when you press the pedal the springs can hit the levers. There is no easy way through the bottom of adjusting the main clutch only the PTO clutch clearance can be done through there. The engine will have to come out to do it properly, if the Clutch is overheating then it is slipping and will wear the plate rapidly so don't use it. You can't put the Bearing carrier in upside down. If one of the levers is at a different height to the others there is definitely no option but to take the engine out again. If you need the info for setting the clutch and making the gauges to do that, email me at:- fergusontractors(at)tiscali.co.uk
