cracked block
mike mcmurray
11-24-2006 16:16:32
Closer inspection of my TO 20 block has unveiled the usual cracks between the cylinders (both upper and lower) for this model tractor. After reading nearly every post regarding "cracked block" I get the idea that I should: Have the head first magnafluxed by a machine shop to see how deep the cracks go. The best fix would be to get it furnaced brazed and align bored. "Pinning" also seemed to be an option, as well as nickel rod welded. Any idea of cost and effectiveness of these options. Pros and COns! I would like to take it to a machine shop early next week for diagnosis, and would like to have some idea of what to expect. Thanks, Mike
Dean
11-25-2006 04:53:34
 Re: cracked block in reply to mike mcmurray, 11-24-2006 16:16:32
Mike:
If you are anywhere near Cincinnati, see my post below.
Dean
Jerry/MT
11-24-2006 17:14:05
Go to your local machine shop and see about a furnace braze repair. It's what you get when you get a remanufactured engine. The block is cleaned and furnaced brazed which also stress relieves the block. It is then remachined and then ready for use. I have one that was repaired this way and it hasn't given me a lick of trouble and mine is a working machine on our ranch.
mike mcmurray
11-24-2006 17:21:53
 Re: cracked block in reply to Jerry/MT, 11-24-2006 17:14:05
Hi Jerry! Any idea on what I should expect this to be financially? thanks a ton, man!
Jerry/MT
11-24-2006 21:26:49
 Re: cracked block in reply to mike mcmurray, 11-24-2006 17:21:53
It's competetive with buying an uncracked block. They go for about $400-$600 when you can find them.
mike mcmurray
11-24-2006 16:25:17
Hey John. How do I go about posting a pix on this site?
John (TR)
11-24-2006 16:20:28
Can yo upost a photo so we know what to look for?
Thanks
