replacing oil pressure guage on TO35
john wilson
11-13-2006 07:43:31
I am replacing a non-working oil pressure guage on my TO35. While trying to attach the copper pipe to the guage I managed to cross-thread it and ruin the elbow joint at the base of the guage and will have to find a new one. My question is whether there is a trick to attaching the pipe to the guage. The room for working in is extremely restricted. Has anyone done this repair before and how did they do it? Thanks in advance for any help you can give.
John Wilson
Jerry/MT
11-13-2006 11:36:46
 Re: replacing oil pressure guage on TO35 in reply to john wilson, 11-13-2006 07:43:31
I'm not familiar with the specifics of you tractor but often times it's easiest to remove the gauge from the panel, attach the tube and fittings with the gauge out of the panel but held in front of the dashboard with the tubing through the dash panel. You can then attach the gauge again with the tube in place.The you need only to hookup the tube to the engine block.
I hope this makes sense to you. It's easier to do then it is to describe.
john wilson
11-14-2006 07:21:36
 Re: replacing oil pressure guage on TO35 in reply to Jerry/MT, 11-13-2006 11:36:46
Jerry: that's great idea, and I will try it, although the bracket on the back of the dash that holds the gauge in place will probably prevent my doing it.
Jerry/MT
11-14-2006 10:02:12
 Re: replacing oil pressure guage on TO35 in reply to john wilson, 11-14-2006 07:21:36
Isn't that bracket attached to the gauge so that's it's removable? You remove that to replace the gauge. I could be wrong becuse i'm not familiar with your tractor's specifics. Gauges are usually easily replacable.
John (TR)
11-14-2006 18:20:51
 Re: replacing oil pressure guage on TO35 in reply to Jerry/MT, 11-14-2006 10:02:12
I just replaced the water temp and oil pressure gauge on the 35. Remove the rubber air cleaner snorkle tube as that will help. I was able to get them out but had to ahve the wire start the nuts on the one closest to the steering wheel (temp) as I can not get my hands under the dash
