TEA20 starter
Boyde from Bram
11-06-2006 05:33:03
I see in the parts manual that there are starters for a TEA20 with serial number less than 200001 and a different starter for a TEA20 greater than serial number 200001.
Can any one describe the difference between these starters?
Sparex lists a starter for a TEA20 serial number greater than 200001, which costs more than a Bare-Co which looks the same, but does not speciffically say for a TEA20 serial number greater than 200001.
Regards
Boyde
Bill Brox
11-07-2006 05:23:03
 Re: TEA20 starter in reply to Boyde from Brampton, 11-06-2006 05:33:03
Hello Boyde,
A 12 volt starter will not fit the early 6 volt TEA 20. The later 12 volt starters has the bendix drive on the backside of the flywheel so there is made a pocket for it in the clutchhousing. The older tractors does not have it, and therefor it will not fit.
Sparex no: S.41136 will fit TEA 20 later than 200000
Sparex no: S.60354 will fit TEA 20 before 199999
A Sparex no S.60354 can be used on a TE 20 with Continental engine if you add a 1/16" (1,6mm) spacer between the starter and the flywheel housing.
I hope this helps, if not ask more.
Bill
HowieNJ
11-06-2006 18:15:28
i put a 12 volt starter on my tea20 is it 6 volt your buying? also te20 was made buy continental motors the tea20 engine was made by the stanerd motor works. to different engines hope this helps.
mn.Chuck
11-06-2006 09:08:26
Boyde, My old parts book shows most every major
part is different. Then I wondered if complete
starter could be interchanged but even though the
flywheel ring gear is the same, the flywheel is a
different part no. For what it's worth my writing
from 45 years ago in that book indicates that the
prior s/n can use a Chrysler 143119 (MZ 41336)
Hope anything helps. Chuck
Boyde from Brampton
11-06-2006 09:59:30
 Re: TEA20 starter in reply to mn.Chuck, 11-06-2006 09:08:26
Thanks, I appreciate the response.
I am looking for a starter for a TEA20 with serial number greater than 200001.
The sparex s41136 specifically states it is for a TEA20 < 200001.
The BareCo B9200 only states it is for the Te20, MF35, 135.
They both look the same. One is less expensive than the other.
John (UK)
11-07-2006 12:00:05
 Re: TEA20 starter in reply to Boyde from Brampton, 11-06-2006 09:59:30
The starter you need for a 12v TEA is Sparex part S41136 which was Lucas 25038. Serial numbers less than 200,001 are 6volt and it is a completely different starter. You need the one with the long Bendix drive (S41136)
Jim W
11-07-2006 06:40:48
The diameter of the hole they fit in is different so it is not possible for them to interchange.
Jim
