pushrods and rocker arm assembly
mike mcmurray
11-04-2006 16:42:07
Hi there...I just purchased a 1951 TO 20. How can I go about locating pushrods (none came with it) and possibly a rocker arm assembly (or atleast one rocker- the other 7 appear fine). Have a good night. Mike
John (TR)
11-06-2006 07:27:15
 Re: pushrods and rocker arm assembly in reply to mike mcmurray, 11-04-2006 16:42:07
I just listed a head and rocker assy on ebay and have the pushrod set but have not listed yet. You can do an advanced search on seller WSL91 and see my auctions as well as feedback or the usual search of Ferguson 20 and see the parts. I don't end aucitons early but you are welcom to bid on them or go elsewhere if you need sooner. I'll turn on the email, send me a message if you are interested in the pushrods.
Thanks
John
maplehillfrm,pat
11-06-2006 05:39:46
this may be the push I need to part out the shell of my TO ,, I dont know what they are worth but I have a set from a complete engine,,,
Willy / 30 OD
11-04-2006 10:31:10
Mike I know someone by the same name. Are you a Iowan?
Gerald J.
11-04-2006 16:47:36
There is a tractor parts company in Indianola Iowa whose name I can't mention here (causes posts to not be accepted) that has the Continental rocker arm assembly.
Gerald J.
Jerry/MT
11-04-2006 17:32:17
 Re: pushrods and rocker arm assembly in reply to Gerald J., 11-04-2006 16:47:36
You can try www.montesequipment.com. They specializes in Continental Parts
Gerald J.
11-04-2006 10:41:46
 Re: pushrods and rocker arm assembly in reply to Jerry/MT, 11-04-2006 17:32:17
Its been years since I checked with Montes for rocker arms and then they had only a few left in stock.
I rebuilt my own with new bushings and I made a whole new rocker arm shaft with several improvements so it won't loose lubrication again.
Gerald J.
