TO30 Pull Starting
Larry Counts
11-02-2006 13:27:41
Hello,
I recently purchased a TO30 and it started fine when I picked it up. After towing it to Michigan from Texas it wouldn't turn over. It clicked like a dead battery. I unloaded the tractor off the trailer and when I tried pull starting the tractor the left tire (clutch side) rotated in the correct direction. The right tire (brake side) rotated backwards. It finally started but was much harder to start with the tire trying to rotate in the opposite direction. Any help with this would be appreciated.
Larry Counts
sunny 4 acres
11-02-2006 14:17:53
 Re: TO30 Pull Starting in reply to Larry Counts, 11-02-2006 13:27:41
Larry use the highest gear to start tractor. Sounds like you had it in a lower gear. Am I right?
