progress on the TO 35
John (TR)
10-30-2006 19:30:40
Started getting some time in on the TO35. I pulled the timing cover to inspect the governor. It looks great. I did find the front pivot shaft worn and bushing very worn. I ordered a new front crank seal since I have the front cover off along with the needed bushing and shaft
third party image
The entire engine was covered in oil. Found the valve cover gasket rolled into the valve area been leaking for along time
third party image
We have parts! This is my new work tractor but I can�t help but clean and paint everything that comes off.
third party image
Heres the front axel next to a TO 20 axel. I can�t find any difference
third party image
And here is a before picture. The previous owner stopped by this weekend and stated it looked better when I bought it, he had no idea what all it needs
third party image
John Mason, Michigan
11-08-2006 11:36:35
 Re: progress on the TO 35 in reply to John (TR), 10-30-2006 19:30:40
John,
Where can I get a air cleaner tube like the one on the hay wagon? Wondering what the radius of the bend is and also the angle. How do you place the pictures?
Thanks. John Mason
Dean
10-31-2006 15:59:29
Looks like a worthwhile project. I've been slowly repairing all of the things needing attention on my MF-35 Deluxe and FE-35. Today I straightened a bent radius arm on the FE. Next it's a PS seal in the column of the MF, then probably injectors on both.
Is that a 9N or 2N in the background?
Dean
John (TR)
11-01-2006 03:27:24
 Re: progress on the TO 35 in reply to Dean, 10-31-2006 15:59:29
Thats a 43 2n, mostly original, wrong colors. Rebuilt it and painted it before I found all the information on the internet. I have an 8n also that I rebuilt last winter including rebuilt motor. Always starts as a work tractor, then needs some attention, then my OCD kicks in and before you know it its a rebuilt mice shiny trator that I dont want to push snow with, then I look for a work tractor and the process repeats.
Dean
11-01-2006 04:19:37
 Re: progress on the TO 35 in reply to John (TR), 11-01-2006 03:27:24
I know the feeling. I find it difficult to leave cosmetics well enough alone but have exercised great restraint lately. I completely restored a 1960 JD 730DWES about 15 years ago. The tractor was bought to be both a hobby and a working machine but, of course, I turned it into a trailer queen and coulddn't use it for anything.
Dean
John (UK)
10-31-2006 10:03:29
There isn't any difference between a late TO30 axle and a TO35 type. When you remove the front axle you leave the Radius rods attached to the axle and then you can move the axle around using the Rods like the handles on a wheelbarrow, just keep the Rods lower than horizontal though or the wheels will steer themselves due to the camber setting. The steering rods should be lifted up and over towards the rear axle out of the way, much easier to work on then. NOw you have detached the governor linkage you will have to reset it all, if you need the info for this email me:-
fergusontractors(at)tiscali.co.uk
John (TR)
10-31-2006 11:29:01
 Re: progress on the TO 35 in reply to John (UK), 10-31-2006 10:03:29
The gov has not been working anyway so I'll have to readjust. Now I know mechanically its ok. Looked like the front crank seal had been leaking so now thats addressed. After pulling the radiator it was apparent that the front axel bushing needed reaplced and when it would not come out I decided to pull the front axel support. It's easier to drive the pin out from behind. I ended up taking it out with the gas axe.
I took the axel apart as I did and wanted to replace the worn bolts that run through the radius rods and axel. I like the idea of rotating the drag link arms over to the rear axel. The front wheels are off being dismounted for new tires and I need to chase the threads on the front hubs. Lots to do!
John (UK)
11-01-2006 03:57:43
 Re: progress on the TO 35 in reply to John (TR), 10-31-2006 11:29:01
The reason for the bolts through the Radius Rods being worn is due to the Front Axle Pivot Pin being worn. The Axle should be held by the pin firmly just allowing it to pivot but when the Axle Pin is worn it throws a lot of loading onto the Radius Rods which are there just to provide support for the end of the axle. If you leave the bolts worn or the Front Axle Pin worn the Radius Rods will bend up-wards in the middle due to the load of the wheels trying to twist the Axle back-wards under the tractor, you will also find that the Axle on the left side will hit the bottom hose connection on the Radiator if you travel over rough ground.
Jerry/MT
10-30-2006 21:34:02
Loooks like you're making lots of progress, John!
