TO 30 Hydraulics
Henry Born
10-30-2006 08:44:37
I have a TO 30. The lever is out of the arc in order to lower the arms. If you put it in the up mode it just keeps on climbing, in the down mode it keeps on falling. I was told that there was a cam that regulated it so you could set it at a certain position and it would stay. I would like to tackle this myself. Problems? Ideas? Books? Videos? Thanks
John (UK)
10-31-2006 09:55:54
 Re: TO 30 Hydraulics in reply to Henry Born, 10-30-2006 08:44:37
The neutral spot should be 2-1/2" from the top of the quadrant if it is set correctly and the Control Spring you should just be able to turn with an implement on the back. but it isn't position control which is what you are talking about. If you want Position Control you need a "Zane Thang" this is the cam you talk about go here to see the site:-
Link
fergusontractors(at)tiscali.co.uk
and tell me what you need. If you need the information to reset your Control Spring and Hydraulic Quadrant, just email me. Why do you want it to hold at one height, maybe what you need isn't possible but I would need to know first.
Jerry/MT
10-30-2006 16:40:43
The TO-30 (and the -20) do not have position control on the three point hitch. There are aftermarket position control devices that can be bought and there are plans available on this site to make your own.(See Parts and Pieces at the left of this page and search for "position control.)
You can find a neutral spot on the quadrant where the hitch stops, but that's not position control. A fraction of an inch either way and the hitch rises and falls. If your control lever is out of the arc, you need to adjust it. John(UK)has the info you need in a form he can email you. Ohterwise the best bet is to get the Ferguson Shop Manual. I'd also advise you to get the parts manual and the owners manual. They are reprints of the factory originals and have a lot of system descritions and specs. Stay away from the IT manuals. In my opinion, they are not intended for people new to these old tractors.
