TO 20 battery
j caleb
10-24-2006 12:12:37
I have a to 20 that has had the generator converted over to 12v. The 12v battery is still hooked up positive ground. What do i need to do to change it to negative ground?(other than switch the cables) Also is there anything about changing over to 12v that would cause the points to burn. My 12v 8n points lasted for years.
Phil(WA)
10-24-2006 21:57:26
 Re: TO 20 battery in reply to j caleb, 10-24-2006 12:12:37
The coil wires must be reversed as well so that the negative side goes to the dist. and positive side goes to the ignition switch terminal.
Phil(WA)
John (UK)
10-24-2006 15:47:09
Usually the problem of burning points is the Condenser, just change it, you can't do anything with it. Open the points too if you are on 12v, this gives the condenser time to charge up, open them to .025" and try it.
CENTAUR
10-24-2006 13:22:13
you will have to repolarise the generator.Is it a two or three brush.A two brush may need voltage regulator attention.CENTAUR
r hood
11-04-2006 14:34:42
 Re: TO 20 battery in reply to CENTAUR, 10-24-2006 13:22:13
On my ferguson to20 the voltage regulator,what connects to the arm connection
John (TR)
10-24-2006 12:31:30
Amp meter needs to be reversed
