TO-30 hydraulic control valve
brian_tx
10-22-2006 17:08:06
After having some trouble with the lift on my 1953 TO-30, I removed the pump unit and disassembled it. I discovered that the spring inside of the lift control valve was broken in two places. Everything else is in fine shape. My town has a Ford dealership, but no MF dealer. Is the control valve from a Ford 9N the same as the one in a TO-30? I know the pumps and lift systems are pretty much identical in function, otherwise. Using the Ford 9N part will get me back to work much faster than obtaining one from MF. Thanks!
John (UK)
10-23-2006 05:44:26
 Re: TO-30 hydraulic control valve in reply to brian_tx, 10-22-2006 17:08:06
The Control Valve is the same on the Ford 9N and the TO30 except the oscillator isn't used on the Ford so it wont have provision for one. You may be able to get the spring separately.
brian_tx
10-22-2006 17:51:41
To clarify, this is an older style valve, with a square oscillator. There is nothing wrong with the valve itself. I just need the spring, and figured if I could save time by buying a Ford valve locally, even if a little different style, then I could rob the spring from it and install it in my existing valve if possible.
