Timing/ valve set 23c deisel
matt jones
11-17-2000 15:07:26
does anyone know the right way to set the timing and how to set the valves on a standard 23c deisel. the it manual is very vague and dosen't make sense. thank you.
Len Dalziel
01-09-2004 21:30:45
 Re: timing/ valve set 23c deisel in reply to matt jones, 11-17-2000 15:07:26
We are in a worse position - we have no instructions at all - there doesn't seem to be any handbooks available for this engine. Using logic though and referring to the CAV injector pump for the 3 cyl perkins, we think we've determined the general timing using the flywheel indexing hole and the 'spill point'?? of the pump. The CAV pump has index marks A thru H. What we dont know is which one is relevant, Can you help. Thanks.
Bob Akin
11-20-2000 22:26:17
Matt,
I just rebuilt my TO-35 and I have done the procedure in the IT manual several times. The procedure is certainly unusual but if followed will provide good results. Make certain that you do not turn the camshaft with the crankshaft in any position other than the position mentioned or you may cause damage due to valve/piston contact. I didn't trust the procedure so I used a degree wheel in order to prove the procedure. Also, my cam sprocket had the holes bored out bigger for some reason and it would fit in any of the six positions. It is supposed to fit in only one position. If you follow the procedure step by step it will work. Good luck
