TO-35 Starting aid
matt jones
11-14-2000 06:17:20
am rebuilding standard 23c deisel the starting aid on the intake is broken, do i need to find a replacement or is there any other method that could be used. I live in florida so i don't know if cold starts a going to be a promblem or not.
twopop
11-16-2000 20:01:39
 Re: TO-35 Starting aid in reply to matt jones, 11-14-2000 06:17:20
i would suggest that you could install an engine block heater in the water jacket and plug it in a couple of hours before your going to use the tractor,it should start easily
Jon
11-16-2000 18:04:30
Matt,
don't bother, I just use the ether, warm days it will start with a little squirt, cold days a big squirt.
Since the tractor and myself are in Melbourne (Australia not Florida) we probably get a little colder than yourself but probably not much.
I am told by the previous owner that the glow plug generally was easy to burn out so was pretty useless. I would also be a bit scared to use the glow plug AND ether - I think that would be a pretty big NO NO. You will need ether so forget the glow plug.
Talfr
11-15-2000 06:23:29
The 23c diesel engines are bad starters anyway. They are renound for it. I live in england which must be a bit colder then were you are, and we dont use the heater in the intake, as we find it is useless. We have to resort to a can of easystart on one tractor - the 23c, which doesnt do the engine much good atall - the combustion is very violent.
I would advise to get her going and see how well she goes. Do not be surprised if buying a new heater hardly makes any difference to a bad starting 23c. Thats my experience anyway, maybe we are just unlucky.
You may find it starts OK in which ase you maybe ant to get a heater to finish the restoration - make sure you get the right one, I think there are a few types.
Talf
