tractor for parts
jeremy b prins
10-13-2006 17:29:56
hello, i own a tea 2085 tractor a 1949 or 1950 i was told, (the serial # is gone, and i am looking for a parts tractor and i found one with a massey harris ferguson badge the serial # is tea-425167 and i was wondering if these parts from this tractor will fit on mine, like sheet metal, gas tank, drawbar,radiator ect. and i was wondering if it is the same size engine, thanks in advance
Dave H (NY)
10-15-2006 12:47:16
 Re: tractor for parts in reply to jeremy b prins, 10-13-2006 17:29:56
Don't know where you are But I have a TO 20 parts tractor. E-mail is open
Irv ( Ia)
10-15-2006 17:57:28
 Re: tractor for parts in reply to Dave H (NY), 10-15-2006 12:47:16
Dave, do you have the heavy spring on draft control for the three point? A previous owner took the one off mine.
Dave H (NY)
10-16-2006 02:32:54
 Re: tractor for parts in reply to Irv ( Ia), 10-15-2006 17:57:28
Irv, it is a complete tractor, and I will either part it out or sell it whole as a parts tractor. In any case it will be listed here, and it does have the spring you are looking for.
Irv (Ia)
10-16-2006 06:21:08
 Re: tractor for parts in reply to Dave H (NY), 10-16-2006 02:32:54
OK, I thought you were going to piece it out yourself. I have found out since that you can still get that spring through Tisco, but I don't know the price yet. Thanks,
Irv
jeremy b prins
10-13-2006 18:09:41
i would also like to add that the carbourator on the tractor im looing to buy is larger then the one on my tea-20 mines a zenith 24t and this other one is alot larger, never got a chance to look to closely but it is still a zenith carbaratour, so would this mean that it is a different engine or just an improved carbaratour?
thanks
Jeff-oh
10-16-2006 07:13:21
 Re: tractor for parts in reply to jeremy b prins, 10-13-2006 18:09:41
Jeremy,
To answer your question. The 2085 is a TEA-20 tractor they are the same. The 2085 is a common term used for TEA-20's that were built with 85mm engine cylinders. During mid-production the engine bore was increased to up the power output. Other than the pistons, and related engine parts the 2085 is the same to other TEA-20'. That said I believe the SN you gave for the TEA-20 is late enough that it too has the 85mm calendars. You should be fine for parts.
Jeff-oh
