TO 30 Timing Chain
Herbert Scribne
10-11-2006 18:05:38
Can I get a new tinming chain for my TO 30, it sounds like its hitting the housing, still runs well so she has not jumped, just this clicking sound like there is a broken link.Before I tear into this I want to be sure there is a replacement chain available.
Thanks for any leads as to where to look.
Herb
gerard
10-13-2006 13:14:02
 Re: TO 30 Timing Chain in reply to Herbert Scribner, 10-11-2006 18:05:38
Might be the governor breaking up (on front of cam gear). I'd not use it again until I'd taken timing cover off to look.
Herbert Scribner
10-13-2006 17:06:52
 Re: TO 30 Timing Chain in reply to gerard, 10-13-2006 13:14:02
Well, after getting ready to drain the radiator and start digging into the timing gear case, I noticed that the generator belt was very loose, so I tightened it up, and started the engine , just to see if that had an effect. Remember, this noise just started, anyhow, after tightening the belt the noise was gone. I drove her about for a while (load & no-load, and never heard it again. I think I was getting some back-lash in the timing gears, and when the belt was tight, it held things together. Anyhow, I will keep an ear to this and if it returns I open it up.
Herb
Jerry/MT
10-11-2006 21:09:43
Your Continental Z129 doesn't have a timing chain. However the nut on the cam that hold the timing gear on may have come loose so you better pull the cover and take a look.
Herbert Scribner
10-12-2006 02:53:08
 Re: TO 30 Timing Chain in reply to Jerry/MT, 10-11-2006 21:09:43
Thanks Jerry, when you suggest to look, where do I start, is this "nut" under the valve cover or am I going for the timing gears area, that is under the water pump, on the front of the engine? The noise sounds like its coming from the front, nearer the bottom of the engine than on top, I have not yet ordered the maintainance maunal, which one do you reccomend??
Thanks for the lead, Herb
Jerry/MT
10-12-2006 09:44:45
 Re: TO 30 Timing Chain in reply to Herbert Scribner, 10-12-2006 02:53:08
You'll have to look under the timing cover, Herbert. I agree with Jeff(OH). Get the Ferguson Shop Manual AND the Parts Manual. You won't regret it. They ahs very good systems description in the shop manual that you won't find in the IT manuals.
Jeff-oh
10-12-2006 05:04:53
I would recommend the shop service manual. DO not bother with the I&T manuals.
