TO 30 clutch
kurt k/ Ohio
10-11-2006 05:13:46
My T O 30 will not go into gear while the engine is running. I dont think the clutch is engaging and I was told that the clutch is stuck. I can get it into gear by idealing the engine at a very low RPM and pushing hard on the shifter. I have tried to get the clutch unstuck by driving it in gear at a high RPM then pushing in on the clutch padel. Is there another way to get the clutch unstuck or is there another problem?
Jerry/MT
10-11-2006 11:56:55
 Re: TO 30 clutch in reply to kurt k/ Ohio, 10-11-2006 05:13:46
Did you just install the clutch or has it been in for sometime. The reason I'm asking is the re is an check/adjustment of the clutch finger height that is required for a new clutch and if that isn't done, the clutch pedal may have insufficient throw to disengage the clutch. (I have that problem with mine and it's just about at the release limit. Whoever put it in didn't do it correctly so it's on my list of things to do in the winter. Gotta' split the tractor.) If you haven't recently replaced the clutch then I's say the problem is the sclutch is sticking to the flywheel from lack of use. Some people block tie the clutch pedal down to prevent this.
To get it to release some people suggest pulling it in gear with your foot on the clutch so that the rear wheel supplied torque will cause the clutch to release from the fly wheel. Since you can start it and get it in gear, maybe getting it rolling and then putting on the brake harshly while stepping on the clutch will help release it.
Check the archives as I believe this issue has been discusssed before.
