TO20 generator pulley
scottjhall
10-09-2006 05:57:20
Does anyone know of a source for pulley's on a 6V TO-20 generator. Mine exploded this weekend and I have not had much luck finding one. The shaft diameter seems to be a bit larger than the standard 5/8" shaft you find on most equipment today. And the 3/4" belt seems to be the other problem.
Any direction someone has besides machining a new one would be greatly appreciated.
Thanks,
Scott
Don Tieche
11-06-2006 16:42:35
 Re: TO20 generator pulley in reply to scottjhall, 10-09-2006 05:57:20
I know Witmer's in Columbiana, Ohio has one.
Contact Gerry Less at 888-427-6025
oldgit
11-01-2006 20:29:18
I found a place with them its called fondy electric in Wisconsin the number ther is 920-739-8996
gerard
10-09-2006 15:31:09
Would take a lathe operator less than an hour to turn one from solid. Done several myself over the years.
Gerald J.
10-09-2006 16:23:00
 Re: TO20 generator pulley in reply to gerard, 10-09-2006 15:31:09
That what the one I bought from JD for my gas 4020 looked like.
The auto electric shop should be able to supply too. That's where I got a small diameter pulley for the alternator that I put on the 4020 that fit the wide belt.
Gerald J.
DennisPinOhio
10-09-2006 06:33:17
I don't know where in the U.S. you are, but believe it or not, I went to an Amish engine shop and they fitted my alternator with a new pulley, and it was an exact match for the belt.
For what it's worth.....
scottjhall
10-09-2006 07:18:39
 Re: TO20 generator pulley in reply to DennisPinOhio, 10-09-2006 06:33:17
I am just north of Ohio in Michigan. Where was the Amish engine shop you found?
DennisPinOhio
10-09-2006 12:54:04
 Re: TO20 generator pulley in reply to scottjhall, 10-09-2006 07:18:39
It was called Yoder"s and was located in Mount Hope, Ohio, near Wooster. Unfortunately, they went out of business some time ago. However, I am sure there are others. One that comes to mind is located near Millersburg, Ohio. I believe it"s called Gingerich Tractor or similar, located on state route 62/39.
You may have to do some research.
Duner Wi
10-09-2006 06:03:32
Last one I got at M-F Dealer. Part# 1750509M1. Was 9 years ago tho. Any good Mom and Pop generator repair shop would have one that would work.
