TE 20 water coming out intake manifold
cleve crews
10-08-2006 08:15:42
My father has a TE 20 that stopped running this weekend, so we took a look at the Marvel-Schebler and saw that it was full of nasty water. We figured this came from the fuel tank. After cleaning out the carb, we tried starting it without the air filter line attached and noticed water coming out the intake of the carb while turning over the engine. Inspection of the plugs showed small droplets of water on a couple of plugs. Currently, the coolant is mostly water, so we couldn't tell if the water was coming from the cooling system or what.
We did turn off the gas and tried it again, only to see more water coming out the intake to the carb. The engine has good spark, but will not fire up, even when using starting fluid.
Anyone ever come across this before?
WVfarmboy
10-10-2006 11:33:09
 Re: TE 20 water coming out intake manifold in reply to cleve crews, 10-08-2006 08:15:42
i would say you have a blown head gasket. the best thing to do is take the head off and have it checked and planed if necesary and make sure there is no cracks in the block. its probably just the gasket and wont cost much too fix.
