Oily plugs
Brendan Burke
11-09-2000 20:20:39
I have a '53 TO-30 that was running fine for years and all of a sudden has seemed to want to foul plugs. The tractor misses right bad, especially on the 1st and 2nd cylinders. Upon removal, the plugs are oily and if I thouroghly clean them, they go right back to work. After shutting the tractor down and letting it get cold, it starts all over again. All I can figure is that oil is seeping in by the valves, perhaps a plugged drain from the valve galley. Any help is appreciated. Oh, Champion D21 plugs. Thanks.
Tex Ferguson
11-10-2000 17:22:22
 Re: oily plugs in reply to Brendan Burke, 11-09-2000 20:20:39
I agree with your first suspicion, Brendan. Or perhaps a valve guide seal or two have disintegrated. A less pleasant thought is a busted piston ring. Be sure to post what you find out. Good luck! Tex
