install clutch
gregorey
10-04-2006 09:49:57
I'm trying to install a new clutch and disc in my 49 to-20. I got the parts from yesterday's tractor.Maybe there is a trick to installing this? I put the disc on then put the clutch cover on and when I try to fasten it to the flywheel I can't. the bolts seem to be too short. Is there a solution? All parts are new. Any help would be greatly appreciated. Thanks, Greg
John (UK)
10-08-2006 05:32:44
 Re: install clutch in reply to gregorey, 10-04-2006 09:49:57
Don't attempt to pull the two halves together or you may damage the clutch plate. You should have the front and rear half with an equal gap all the way around and pull the engine in to the gearbox using the Radius Rods and rocking it slightly from side to side at the same time. Don't force it. You can use a couple of long steel screwed rods, screwed into the gearbox housing as guides. Did you make sure that the new clutch plate slid onto the drive shaft easily, if not clean up the splines, don't use any oil or grease on there as it will collect dust off the clutch plate and start to stick. You need a couple of wedges, one under each side of the front axle to prevent the engine rocking over. Apply the brakes hard so the rear end won't move.
Jerry/MT
10-04-2006 11:07:54
Are you sure that you have the clutch disk facing the correct direction? The side with the shorter hub goes toward the engine.
