Plug fouling
Randyr
10-04-2006 03:50:02
On my 35 gas with Z134 engine, the #4 plug fouls up and misfires. Cleaning it doesn't help, it must be getting fouled further up the ceramic center and shorting out there, I guess. It's an oily fouling but the cylinder had 145 #s compression. Right up to snuff. It makes me think it's the valve seals/guides leaking oil into the cylinder when cool, then taking up the slack when hot, dirtying the plug in the process. If the plug can make it through the warm up still firing, it will be ok when warmed up.
My question: How can I keep the plug firing on a cold start through the warm up when the cylinder is oily?
And how can I properly clean the plug? I even tried burning out the deposits with a propane torch with no luck.
It's 12 volt with Pertronix ignition, and runs good when #4 is working. Would a hotter plug help? Have had Champ D21, and NGK A6. Maybe a wider gap, hotter coil?
What do you recommend?
woodsey11
10-08-2006 03:31:24
 Re: Plug fouling in reply to Randyr, 10-04-2006 03:50:02
I have a 46 0r 47 Harry, Same problem, I put 2 wedges between distributor and engine block and it hits on all four. I think i need a rebuilt distrib, have not figured how to pull old and put rebuild back with out haveing to time it?
Duner Wi
10-05-2006 18:56:23
This usually works for me. Pull the plug wire off the plug so spark has to jump 1/4 inch to spark plug. You can use a popsicle stick and rubber bands to hold the wire. Fergusons usually don't over oil the top end or at least mine don't.
Dean
10-05-2006 16:46:07
Randy:
As you say, it sounds like oil is getting past the valve seal on #4.
If you can find them, "NO Foul Adapters" were once made for this type of problem. NAPA and J.C. Whitney both still had them about 10 years ago but I have not seen any lately.
I have used these in the past in engines that oil foul the plugs and they do indeed work. If you can find a set (or even one) you will probably be able to get by for years.
Dean
Randyr
10-04-2006 13:05:44
Yes it makes blue smoke on initial startup and then cleans up as it heats up.
I'm sure it needs head work, but it will have to wait. Until then I put in a new plug when misfire shows up and it runs fine. The plug stays clean once hot, fouls when cold and smokey.
Is an Autolite 386 better and less prone to fouling than a Champ D21?
Thanks.
gerard
10-04-2006 12:09:12
I would guess the fouling only appears oily because of the misfire. Was the engine smoking badly / using oil? If not, it"s not an oil issue, but an ignition one. Once a plug has been fouled, only place for it is the bin. Even a commercial grit blaster won"t rescue it.
Gerald J.
10-04-2006 11:50:18
Try a non resistor AC or Motorcraft plug. Hotter heat range won't hurt. Modern Champion plugs seem to foul easily and not to be cleanable.
Be sure the wires are copper, not carbon.
Gerald J.
Jerry/MT
10-04-2006 11:16:10
You seem to have lost oil control on #4 or, as you suspect, the valve seals are leaking.(You could also have a bad plug wire or a corroded terminal in the cap that causes a misfire.)The cure to your problem is to fix the root cause, i.e., loss of oil control. In the mean time, a hotter plug might help. There are spark plug hole inserts that move the plug out of the combustion chamber slightly to help with this problem. The fact that you have a Pertronix ignition says your spark should be hot enough and adding their "super coil" might help by allowing you to open the gap but you really need to deal with the root cause because the rest of the stuff is just a band aid.
