TE20 lift problem
Bradkenworth
10-03-2006 16:32:46
My TE 20 tractor will lift the lift arms without an implement on and stay up. It will not stay up with a blade attached. It was working perfectly fine then all of a sudden it stopped lifting. If I push down on the lift arms they drop (without an implement). Once shut off they drop fairly quickly and I hear a hissing sound from up top. I looked for a leak in the control valve area and found none. I drained the oil to see if the control fork is attached and it is.
Any suggestion?????
Jerry/MT
10-03-2006 21:22:15
 Re: TE20 lift problem in reply to Bradkenworth, 10-03-2006 16:32:46
You may have a leaking cylinder(a crack or just worn seals). Open up the rt side access port and, with the pump engaged and running, look up underneath the seat and see if the there is a lot of leakage from area of the cylinder. A few drops are normal. If it's really leaking from the area, you'll need to either replace the cylinder or the seals. The other area for a potential leak is the supply tube to the cylinder which is in the front right hand corner of the case.
Bradkenworth
10-05-2006 15:21:36
 Re: TE20 lift problem in reply to Jerry/MT, 10-03-2006 21:22:15
Thanks JerryMT that is exactly where it was. I didn't think to look way up under but there it was.
