TO-30 Project Update
pojo
09-27-2006 06:41:32
Well, could not pull the PTO shaft out the back by hand. Decieded to split the tractor to see what the problem was. It took longer to find enough suitable blocking to support the 2 halfs, then it did to split it. The tractors are so easy to work on! Could not find any evidence of a twist or burrs on the spline, one tap with a brass hammer, and it slid though the hydro pump. I will replace the entire shaft with a new 1-3/8" shaft assembly offered on this site parts list. Also, having the tractor split I was able to clean the hydro section.
John (UK)
09-28-2006 10:20:04
 Re: TO-30 Project Update in reply to pojo, 09-27-2006 06:41:32
Your efforts were not wasted if it gave you chance to clean the sludge out of there.
John (UK)
09-28-2006 10:15:45
