Pertronix
Paul F B
09-26-2006 22:43:20
Can anyone help me understand the advantage of Pertronix? I,m confused. Paul F B
DennisPinOhio
09-27-2006 05:28:34
 Re: Pertronix in reply to Paul F B, 09-26-2006 22:43:20
If you are referring to the Pertronix Ignitor, the main advantage is that it eliminates the points and condensor, both of which are prone to problems. Further, the Pertronix set up is similar to the more modern and proven design, using a stator, or magnetic pick up, and an armature.
I put one on my TE 20 and it starts as soon as you touch the key.
Paul F B
09-27-2006 09:21:09
 Re: Pertronix in reply to DennisPinOhio, 09-27-2006 05:28:34
Dennis, that sounds great as I have had condenser problems in the past. What did it cost you to make the switch? Can the shift lever still be used to start the tractor i.e. turn on the key and then start the tractor by pushing the lever to the "S" position?
DennisPinOhio
09-28-2006 07:12:27
 Re: Pertronix in reply to Paul F B, 09-27-2006 09:21:09
I spent around $130 USD for the distributor kit and the proper coil to go with it. I obtained it all from Retro Rockets, on-line.
See John(UK)"s post below for the rest. This changeover has no effect on the starting method.
Please let us all know how this works out for you.
Paul F B
09-28-2006 10:00:56
 Re: Pertronix in reply to DennisPinOhio, 09-28-2006 07:12:27
Dennis; I probably will wait until I need a tune up to add the upgraded ignition. We have a 15 mo. old baby and money is tight right now. Thank you both for enlightening me to Pertronix, I really would like to get it. Maybe Santa? Paul F B
DennisPinOhio
09-29-2006 06:55:12
 Re: Pertronix in reply to Paul F B, 09-28-2006 10:00:56
I hope you get it as it is worth waiting for, considering all the headaches it will solve. Believe me, I don't miss fooling around with the points when my tractor wouldn't start.
Congrats on the new baby, the number one priority now.
John (UK)
09-27-2006 11:10:27
It all fits inside the distributor, you cant see anything of it, just leave out the contacts, condenser and rotor. It's about $90 from this site:-
Link
They do suggest that you fit the coil as well to get the full benefit from the kit (well they would) but those that have fitted them think they are marvellous.
You don't do anything else to the tractor so everything operates as it should.
