transmission and hydralic fuild
Tom Taylor
09-26-2006 19:36:53
I have a massey ferguson f40 1957 under the seat on the right side there is a dip stick for checking the transmission and hydralic fuild. this old tractor has a nail as the dip stick!! can someone tell me the length of the correct dip stick from the top where it stops to the bottom end of the stick, in inches? and what type of fuild does this f40 trator use? Thanks
Jeff-oh
09-28-2006 06:20:29
 Re: transmission and hydralic fuild in reply to Tom Taylor, 09-26-2006 19:36:53
I think Phil's finger slipped. TO-20's -30's -35's take 6 gallons of oil. Using the bottom bolt of the inspection plate as a guide is acceptable.
John (UK)
09-28-2006 10:28:26
 Re: transmission and hydralic fuild in reply to Jeff-oh, 09-28-2006 06:20:29
I think we have our wires crossed here guys, the F40 is the same as the 35 and it takes 8 US galls, the TO20/30 takes 6 US galls. The misunderstanding could come about if you have read the quantities for the UK models as the amounts shown are different:- 5 IMP galls for the TO20/30 and 6 IMP galls for the 35...but it still means the oil should just come out of the bottom setscrew hole on the inspection ports on both types to be correct.
Jeff-oh
09-28-2006 14:27:07
 Re: transmission and hydralic fuild in reply to John (UK), 09-28-2006 10:28:26
No the confussion comes from the fact that I did not fully read the post. I did not pick up on the F-40.
I stand corrected.
John (UK)
09-29-2006 03:55:48
 Re: transmission and hydralic fuild in reply to Jeff-oh, 09-28-2006 14:27:07
Jeff. You have done what I sometimes do by not always reading it fully due to lack of time. It is so easy to miss something especially when it isn't always written that it fully makes sense and you have to puzzle it out.It's not the worst thing that could happen, so put it down to just one of those things that occur occasionally.
John
phil(va)
09-26-2006 19:52:56
Oil should be just to bottom of the round inspection hole. Pull a bottom bolt and that should be the level you are looking for. Dipstick is as long as it takes for top of full mark to be at that level. Tractor takes 8 gallons of GL-1 or 10-40, not GL-5.
