rewire generator to 12 volt?
John (TR)
09-25-2006 04:35:10
I recently picked up a 6 volt TO 35. I converted my 8n to 12 volt some years back and prefer 12 volt on my working tractor which the 35 will be. I read in the archives about having your genny rewound for 12 volt. Has anyone had this done? What kind of money is it? I'd like to run 12 volt and dont want to loose the Tach/hour meter
Thanks
John
Duner Wi
09-27-2006 18:22:11
 Re: rewire generator to 12 volt? in reply to John (TR), 09-25-2006 04:35:10
I think the late TO35s were 12 volt. Might be worth looking into.
Gerald J.
09-26-2006 11:51:46
I've been the rewind route. Then I learned about DC motors and generators. All you really need to do is to hook up a 12 volt regulator and turn the generator faster. Since you want to keep the tachometer drive you can't change the pulley, but you can just have to run the engine faster to get a charge. A true 12 volt field may run cooler and may charge at a slower speed, but I'm not sure its worth the bother. Getting the field pole screws loose with ordinary tools isn't easy.
Gerald J.
Bruc
09-25-2006 17:37:10
Check EBAY and punch in "Triodiode". I believe that is correct. He should have the field pieces to convert your genny to 12V. About $25 I think is what I paid.
Bruce
