TO-35 - Spark Plugs / Carburetor
ScottF
09-21-2006 12:58:58
Does anyone know the standard spark plug gap for a Ferguson To-35. I checked the gap on all 4 old ones, and they were all extremely different.
Also, I bought a Tisco Carburator Repair Kit (BK201V) for a Carter carb, and I had a question about the throttle shaft. Is there supposed to be a seal/gasket of some kind for the hole where you insert the new shaft?
Thanks in advance for your help...
Jerry/MT
09-21-2006 13:08:01
 Re: TO-35 - Spark Plugs / Carburetor in reply to ScottF, 09-21-2006 12:58:58
I believe the Autolite 386 gapped to 0.025" is the proper plug. If your plug gaps are different, then who ever installed them my not have gapped them properly. regapp the ones you have to 0.025"- 0.027"
Your carb should have dust shields in the throttle shaft. Make sure that you have the correet kit for your carb. Do you have a brass tag on the carb to provide the Carter modelnumber?
ScottF
09-21-2006 13:27:39
 Re: TO-35 - Spark Plugs / Carburetor in reply to Jerry/MT, 09-21-2006 13:08:01
Thanks for the info on the plugs!
I called a million dealers and restoration companies about this, because I was originally looking for a 'complete' kit, and they only offer one. The rebuild kit is for OEM Carb #s 181578M91, 182748M91, 184458M91.
I didn't find a tag on the carb, but the bowl has:
CARTER UT 0-985 in raised letters. The upper portion of the carb has: 0-834 in raised letters.
Don't know if this helps...
THanks,
ScottF
Jerry/MT
09-21-2006 15:28:09
 Re: TO-35 - Spark Plugs / Carburetor in reply to ScottF, 09-21-2006 13:27:39
Your Carter carb model for the TO-35 should be UT 2223S. I don't have a TO-35 ( I have TO-30 with an M-S carb)but I have a rarely found Carter UT 997-S that was used on the TO-30 and I have the Carter data sheet for the carbs on the TO-30 and the TO-35. The Carter part number for TO-35 carb (UT 2223S)gasket kit is No.259 and the repair package is No.1782. The shaft seal is Carter part no. 163-21 (choke and throttle shafts) and the seal retainer is 136-131(choke and throttle shafts). Try ther www.carburetorshop.com for a kit. They have them or will make one up for you.
ScottF
09-22-2006 05:18:26
 Re: TO-35 - Spark Plugs / Carburetor in reply to Jerry/MT, 09-21-2006 15:28:09
Jerry,
The website you sent me to is a portal to a bunch of other websites. Is the website I need found through this portal?
Thanks,
ScottF
09-22-2006 05:04:06
Thanks Jerry/MT! Do you have the carter data sheet for the Carter carbs on an electronic copy, or can you fax it to 978-418-6530? Just thought I would check. I will check on the seals at the website you provided. What are the risks involved if I don't have the seals???
Thanks again for your help! THis forum is great!!!
Jerry/MT
09-24-2006 19:38:56
 Re: TO-35 - Spark Plugs / Carburetor in reply to ScottF, 09-22-2006 05:04:06
Just got back into town. The risk of running without the seals in leaning out the mixture because the throttle shaft is below the main metering section. Lean mixtures can cause the exhaust valves to burn and the Continentals run a bit rich to cause charge cooling (evaporative cooling). I don't have an electronic copy of the carb data sheet nor do I have a fax machine so you're out of luck there.
Thw web site I should have given you is www.thecarburetorshop.com and it is a direct link not a forum.
