Thanks John (UK) on lift problem.................
RonW
09-16-2006 17:47:09
Back on 9/10/06 I posted about stumpsetting my boxblade and losing my lift. I followed your instruction John, and got it working again. The top link seemed to be ok, so I pulled the sidecover. As you said, I moved the little roller back and forth. There were 2 thin levers sticking down in front of it. They were apart, but moving the roller lined them up together. I guess that was the problem. I started it up before replacing the cover and hit the lift lever. Raised up like a charm.Many thanks John..... ..... ....RonW
John (UK)
09-17-2006 11:51:27
 Re: Thanks John (UK) on lift problem............. in reply to RonW, 09-16-2006 17:47:09
Glad you were able to get it going again Ron. If the levers were not side by side then the valve was stuck as we suspected..Well Done....John
