generator alternator conversion
John in MS
09-14-2006 16:44:27
I plan to convert my 1950 TO-20 to 12V using an alternator. Do I need to be concerned about the size of the pulley on the alternator? The one that comes on it is too small for the existing belt. Can I use the pulley from the old generator?
Thanks
dfitch
09-15-2006 03:08:24
 Re: generator alternator conversion in reply to John in MS, 09-14-2006 16:44:27
John when I converted I was able to use the old
pulley from the generator on the new alternator. I did have to install a thin spacer to keep the pulley fron touching the alternator cooling fan. My tractor is a TO30 and the alternator is a Delco
GarryinCT
09-14-2006 18:13:17
If using a delco alt speedwaymotors.com or others have them speedway's part number is 910-16250 this is for a 5/8 belt.
PD
09-14-2006 17:14:37
Do you have a problem with using a generator? Contrary to the information on this website, your 6-volt generator can be rewound to 12 volts. This procedure used to be my specialty when I restored cars. Worked especially well with Ford V-8's. I also did this to my '49 TO-20. I had the generator and starter rewound to 12 volts, added a 12 volt voltage regulator, a new wiring harness, reversed the amp gauge, added an Ignitor to the distributor. Works like a champ. A size 22 battery is basically the same size as a 6-volt. I changed the coil to a 12 volt with internal resistance. The light bulbs have 12 volt equivelents. The conversion is impossible to detect without raising the hood. I didn't feel that my tractor required all the power that an alternator would produce, and I wanted to keep it as original as possible. I have done this on Kaisers, Packards, a Hudson, several straight 8 Buicks, and the afore-mentioned Ford flathead V-8's. All the best..... ...P
John in MS
09-16-2006 06:04:15
 Re: generator alternator conversion in reply to PD, 09-14-2006 17:14:37
Thanks to everyone for all the great advice. The old generator is completely shot. I checked into having it rebuilt and rewired, but it was going to cost more than replacing it with an alternator. Over the years someone had already done a partial 12v conversion, so at this point it was just a matter of installing the alternator. Although I would like to keep it as original as possible, I really need a functional tractor. Somewhere down the road I might restore it to its former glory when I have the time and patience.
acmfmh
09-14-2006 17:04:50
Use the pulley from the generator.
